We spend hours tryin to get it in but it was not aligning right. when we mounted the driver side mount the passenger side mount was no where near where u can slide the bolt thru. we had too take the mount off and use a drill and shave off some metal where the bolts go thru to the tranny. and we still had to use a crowbar to shift the engine enough to put the bolt thru. and we even left out the rear bracket for later but now it seems alittle diffecult to install it after the engine is in. if someone understood me and can give me ur opinion please do. the passenger side mount is from the civic but i dont think that could be the reason is it?
Tomorrow we are gonna install the rear bracket. can someone tell me whats the right way to this?? i am gonna do it from underneath and it seems like the bracket that is at the bottom of the intake manifold is in my way. any suggestions would be greatly appreciated.
also does anyone know if i can use the automatic tranny shift cable from a 93 integra?? we are using a B18B auto in a 94 civic 4dr.
