If you install it right, it will work right. Why don't you just sell the cable tranny, and get a hydraulic (correct for your car)? There are ALWAY people looking for the cable trannies.
I needed to get a hasport tranny mount cause with the gsr motor mounts the motor has crooked, I went through two cables with that tranny and the 3rd synchro started to go, I went with a hydro 3 months later. Good luck.
the swap is easy to do use your original padle and hydro lines....all you need is the mounts..and the special brackets.. hasport will give you all the instructions necessary for swap.....is cheaper to do this swap(because tranny is easier to get)!!!!i have 3 brand new place racing mounts (kit) for 300 right,left and rear... will ship to your place for $350 let me know.. this kits retail for 600+.....take care.. jdmproducts@hotmail.com
