I have the hasport tranny kit in my 93 DX coupe, along with the 93 integra motor, be careful doing this swap, sometimes the grounds for TPS, O2 sensor, IAT sensor and coolant temp sensor need to be re-run due to who knows what. I have had absolutely no problems with the tranny kit, I actually think its awesome, follow the directions when installing it and there will be no problems what-so-ever. I love it because it is just like having a cable clutch system because the hardware that they give you for it it adjustable, so if you don;t liek where your clutch actuation is you can shange it to be higher or lower (pedal). the only thing I can comlapin about is that the mounts are stiff, so when the car is cold they rattle the hell out of the car.
