hatch blows ecu fuse
mad_hatter
Its Da Mad Hatter
ok well i got the car i was told it runs good but there was no key, i got the key no fuel no spark, found it was the acg fuse under the dash it starts right up, ok the battery was dead, so i put another in it jump it that battery was bad to i rev it up it shuts off and the alt. smokes a little, i change the alt., wont start, its blowing the ecu fuse, i changed it blows again, i pulled the battery and just jump it still, any suggestions, i havnt done anything else to the car and before that it ran good when i first got it going, started right up and everything, so i dont have a short unless it just started on its own i haavnt messed with anything, i saw another thread said the o2 sensor wire hits the exhuast but its not, and how can i tell officially if ecu is the problem
