Have a 2000 civic si Prop valve...ABS or NO?
Discussion in 'Wheels / Suspension / Tires / Brakes' started by hybrid89, Jul 21, 2005.
  1. hybrid89
    hybrid89 thistownsucks...
    SoCal
    anyone know if all 2000 civic si's had ABS or not. I am asuuming they did. I have a prop valve from one, but not 100% sure. TIA
    matt
  2. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    as far as I know they did not have ABS. I remember this guy I knew saying that he locked them up several times. unless he had a 99 and they went to ABS in 2000. :shrug:
  3. abdelsol
    abdelsol Member
    Are you converting something? What are you using it for. There is a thread that the prop valve was thoughly discussed. Since then I talked to Brian at Fast Brakes and we both agreed that the differences are very small if any. In 99.943225656452% (pissedoff's style number) of the cases you will not know the difference.
    Do a part search in the online honda dealers and see if the part number is different.
    I doubt the the prop valve is different between ABS and Non-ABS.
    What is stamped on the outside.... 4040?
  4. jamesA
    USDM Civic Si's never even had the option of ABS. Canadian SiRs (US Si equivalent) had ABS though.
