Have come to problems during the swap
illmatik
ok its been a long time now with out my car, 92 civic hb. the project is almost done, a 99 GSR OBD-2 into a 92 Civic HB OBD-1, but problems keep occuring. One thing is that my mechanic says I dont have an O2 Sensor, so i guess i have to buy one, but ive been told the O2 Sensor for the 99 GSR comes in the Header. Thats one problem, another problem is I bought the rear transmission bracket instead of the Tranmission mount( im a dumass ), i want to know if the transmission mount for the DEL SOL VTEC is the same as the 99 GSR, because i ordered the DEL SOL VTEC Transmission bracket, and to make an exchange i would have to buy the DEL SOL VTEC transmission mount. My Question is would the transmission mount fit,( the picture is here http://www.hondaautomotiveparts.com/auto/j...E+MOUNT+%281%29 #15 ) or would i have to buy the GSR transmission mount( http://www.acuraautomotiveparts.org/acura/.../prddisplay.jsp ) and why are the prices different? and does the O2 sensor come inside the header? correct me if im wrong its what ive been told, i guess i have to go buy a new O2 sensor, because my car started up but then it ran like shit, so then he shut it off and now it doesnt start, it cranks but it doesnt start, i think its either O2 sensor or its wired wrong somehow.
the del sol vtec mount should be the one and on the o2 sensor if you are running obd2 there are 2,1 in the cat and 1 in the collector part of the header.......if obd1 there is one in the collector of the header....junkyard one should do just fine,ne obd1 civic will work
the o2 sensor in your d header should fit just fine
