have spark, fuel, and engine cranks but no start
Discussion in 'General Tech and Maintenance' started by sbaker0421, Mar 20, 2004.
  1. sbaker0421
    sbaker0421 Junior Member
    Can someone help me? As I put in the title I have spark, fuel is going through the lines, but the engine just keeps cranking over and over and never starts. I posted a similar problem to this a few months ago, however, I fixed it by putting a new positive battery cable from honda on there. I've already checked that cable and it checked out okay. Has anyone had this problem. If so could you please help me!!!!!!!! My car is 91 crx si.
    Thanks
    Shawn
  2. h22bubbleback
    h22bubbleback Senior Member
    North Jerzey
    check ur timing, maybe u have no compression
  3. arpee79
    arpee79 Senior Member
    MAKE sure the wires are in the correct ORDER .1 3 4 2
  4. hybridsol
    hybridsol Senior Member
    ohio
  5. tab
    tab Super Moderator
    Aberdeen, Washington State
    yeah, make sure your wires are correct.
    The cylinders as you look at the engine go 4 3 2 1, and the firing order is 1 3 4 2.
    If that doesn't work, check the compression.
