The b18a swap in my 91 crx Si just wont ever get finished :unsure:
Checked the timing it was WAY off I set it tdc on the cams and crank only, both cams arrows point stright up right?
then replaced teh coil and ingnitor and cap with my known to work Si distributor...and still no sparky
It should fire even with some unattached vacuum hoses right?
and what if timings off by a tooth I should still be getting spark no?
Oh and Im not seeing the rpms fluctuate when cranking.
im stuck help thankx
