having trouble with my 2001 integra gsr
dohcgsrb18
The whole motor was rebuild recenting but its having a little trouble. it starts right up but when i put it in first gear and then press on the gas and try to drive it. it would go a little but it hestitate then the motor turns off. what could it be!?!? please help
sounds like fuel or timing. is there any check lights on
you should turn it on then once is on, while the car is parked try to rev it up to all it goes to, if it revs up with no problem then its not your fuel, it would be your tumming
