Having Vtech problems!!!!Help
teg2fast
:eek: to start I have a 95 ls (obd1) with a 2001 gsr motor (obd2) and a p72 ECU. Now to wire the vtech I know it's Vtech Solenoid A4, Vtech oil pressure sensor D6, Vtech Ground Black wire, and knock sensor D3. Once I've done this my vtech still doesn't kick in... I''m doing something wrong? need help..
Originally posted by Afipunk21@Sep 7 2003, 06:29 PM
Is the phone plugged in?
HAHAHAHAHAHAHHAHAHAHAHAHAHAHAHAHHAHAHAHAHAHAHA
dude, i think your VTECH needs to be running at 900Mhz....
what ECU are you using to run this mess?
are you throwing any codes?
Originally posted by Afipunk21@Sep 7 2003, 07:16 PM
He's using a P72
These wiring poblems are kicking me in the but.
And no I'm not plugging in a phone..........
is there a wire I'm messing and can I put honadata on my car even though I'm running a p72 if not what are my choices.
He said that because you can't spell VTEC
you need to give us more info dude.
there's 3 different p72 ecus.
if your using an obd1 ecu, you need to make a wiring change. see the swap section, click 5th gen, see obd2 b18c into 5th gen civic. we have tons of info outside of the forums on this site. i suggest you take a look see
