Hawk Brake Pads
Discussion in 'CorSport' started by CorSport, Jun 16, 2010.
  1. CorSport
    CorSport Member
    For a better stop choose Hawk!
  2. CorSport
    CorSport Member
    94-01 Acura Integra Hawk Quiet Slotâ„¢ Brake Rotors - Front Pair
    [​IMG][​IMG][​IMG]
    Click here to see this product in our catalog and check out the most current pricing.
    Hawk Quiet Slotâ„¢ Brake Rotors (2 Rotors)
    Features and Benefits
    Noise Dampening Steel Formulation
    Long Grain Carbon Iron For Max Durability
    Molybdenum Additive For High Temp Strength
    Thermal Crack Resistance
    Unique Alloy Blend
    Design
    Quiet Slotâ„¢ rotors combine the look, feel and durability of a true performance rotor with the fitment and convenience of OE design.
    Performance design – Direct OE replacement.
    Unidirectional vanes eliminate the need for left and right side rotors.
    Optimal rotor vane and wall thickness improves structural strength, noise dampening and heat capacity.
    OE style vane design combined with increased heat capacity dramatically improves brake pad and rotor life.
    Quiet Slots
    Hawk Performance® Quiet Slot™ rotors feature a unique slot design specifically engineered to improve your car's braking performance and driver comfort.
    Increases initial bite.
    Improves wet weather brake performance.
    Effectively removes gas and wear debris.
    When the brakes are not engaged, the Quiet Slotâ„¢ rotor vane and surface slot design effectively cuts through the surrounding air flow virtually eliminating the "whirling" noise typically encountered with cross drilled or heavily slotted rotors.
    Visual wear indicator. Rotors should be replaced when slots are worn down and no longer visible.
    Optimizes overall brake performance.
    Surface Finish
    Swirl ground surface for improved brake pad bed-in and "green" out of the box performance.
    Specific RMS finish accelerates the creation of a proper transfer film when run with Hawk Performance® brand brake pads.
    All rotors are finished with a GEOMET® coating that protects both the internal and external surfaces from rust and corrosion.*
    Hawk Performance will warranty products to be free of defects from workmanship and materials
    If you have any questions you can reply to this thread, send us a pm or use the contact us page on our website.
    Thanks for the continued support,
    CorSport USA.
  3. CorSport
    CorSport Member
    Hawk pads and rotors ready to ship.
  4. CorSport
    CorSport Member
    Hawk in stock!
  5. CorSport
    CorSport Member
    Get a set of Hawk pads to fill the stockings of that car lover you know.
    CorSport: Hawk
