yes already wired over but not with a p28 wired over with a pm6 ecu and i know its done correctly for i went over the wiring many times to make sure it was correct
yes it is is easy, when I did my vtec swap I just went to Rywire - Online Store and got a jumper from obdo to obd1 for my ecu and it had a plug for a wire that goes up to my vtec/4 wire o2 sensor, way easy to do. I didn't have to change any plugs or anything just plugs right in. You will be much happier if you make the vtec work rather than having the potential and not using it.
