I have the head on my DX 16 Valves 95 removed. I set the engine to TDC
Valves closed on cylinder number one just before I removed the timng belt.
Would that be OK when I install the new Belt?
Any advives will appreciated.
Thanks
go to this link http://tech.hybridgarage.com/tech/manuals/EG-servicemanual.pdf
and starting on page 122 is where it gets into timing belt checking and replacing. Just read it over and if your not sure about some stuff try to get someone to help you out and hopefully also increase your knowledge about your engine. But try reading the entire thing thru once first. just be sure to find which engine you have to you know your looking at the right info. If you have a 1995 civic DX, which is what i have too, then your engine will most likely be the D15B7
