head gasket:
Discussion in 'Engine Building' started by mynumber1hater, Sep 24, 2009.
  1. mynumber1hater
    mynumber1hater New Member
    B18c1 bottom end
    GSR crank and rods
    CTR .25 over pistons (PCT)
    ARP head studs
    ITR water pump
    B16A oil pump
    NEW tensioner
    DC sports 4-1 header
    head:
    B16A head, ported and polished, 5 angle valve job
    ITR cams
    ITR valve springs and retainers
    ITR injectors
    B16 intake
    THIS is my set up what head gasket do i need? part number too please.
  2. Adrupel17
    Adrupel17 New Member
    Yokosuka, Japan
    It really depends on what you want to do. If you want to go NA and raise your compression a little then buddy club makes a thin head gasket. Otherwise just go with a OEM. Sorry dont have the part numbers on me.
  3. DESPAIN
    flower mound TX
    Cometic head gasket. google them and call them up. they will tell you what you need.
  4. mynumber1hater
  5. Adrupel17
    Yokosuka, Japan
    Read around on the posts though, I have seen a lot of complaints on the Cometics leaking/ not lasting long at all, but that can always be inproper installation as well. Are you going NA or possible forced induction?
  6. DESPAIN
    flower mound TX
    cometics are tried and true. Anything wont lastm long if not done right or abused......... I have a cometic head gastket and it has worked great for me.
