Head Gasket
Discussion in 'HYBRID -> EG-EK / DC' started by snwbrdr1, Jan 11, 2003.
  1. snwbrdr1
    snwbrdr1 Junior Member
    does anyone know the thickness of the stock b18b head gasket?
  2. E_SolSi
    pretty sure its 0.6mm
  3. snwbrdr1
    no i dont think so. if my math is right then that would give it a compression ratio of 9.5:1. the b18b has a comp. ratio of 9.2:1. i think its actully 1mm but i just want to be sure
  4. pissedoffsol
    get a helms.
    helminc.com
  5. snwbrdr1
    is that your answer to everything? if i wanted to spend $80 on a book of this information i wouldnt be asking you guys, now would i? i guess i better make my questions easyer for you guys like "dude where can i get those dope clear taillights dude?"
  6. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    There is no reason to be a dick. A helms is the most useful book you can buy for that car. If you have the calculation set up that figured 9.5:1 compression with a .6mm gasket just put 9.2:1 in and back solve for the gasket thickness. Shouldn't be to hard.
  7. snwbrdr1
  8. lsvtec
    If your numbers for everything else are correct and the forumla that you used is correct then you should already know how thick the stock gasket is.
  9. snwbrdr1
  10. lsvtec
    Then what are you bitching about?
