I have a '95 Civic with the 1.5-16v engine. I just replaced the water pump/timing belt (had fun with crankshaft pulley bolt!). I've had a major loss of power and overheating/coolant loss issues for the last couple of weeks. I know for a fact the water pump was leaking, hence the coolant loss, but today when I took the valve cover off I discovered water in the oil. I read a great write up with pics on how to do my head gasket but mainly wanted to ask if I need to take the distributor off of the head in order to remove the head from the block. First post here.... long time reader. Any help is appreciated.
