head gasket
Discussion in 'General Tech and Maintenance' started by SolidDreamz, Oct 16, 2002.
  1. SolidDreamz
    SolidDreamz Senior Member
    va beach,pa,oh
    Ok im about to throw everything back together. Should I rtv the gasket on or not. Also when i took of my distributor i didnt mark spots to put it back exactly the way it was on. I know on hondas you adjust your timing by rotating the distrib. forward or back. What should i do when I throw back on the distrib? put it straight in the middle and try to crank over the car? any suggestions would help me out alot. Thanks!!!!!
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    NO NO NO NO NO NO NO
    Don't RTV it. Get a new gasket.
    Fro the distro, get a timing gun and set ignition advance.
