head question
Discussion in 'Integra' started by jlaurs, Mar 13, 2007.
  1. jlaurs
    jlaurs New Member
    I have a buddy who just got a 94 integra and i have a head from my gsr. now will a head from a b18c fit on a b18b?
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yes
  3. myah
    myah Neu Impact Performance
    ks
    yeah thats y they call is ls vtec buy golden eagle ls vtec kit and gsr water pump and you got your self a good motor
  4. myah
    ks
    o yeah u need a gsr timing belt with that water pump
  5. tartymctang2357
    tartymctang2357 Grand High Wizard
    philadelphia
  6. myah
    ks
    technically you don't but it's better if you do have it your looking at about 500 in parts right their
  7. brian11to1
    brian11to1 Senior Member
  8. tartymctang2357
    philadelphia
    why would you build an ls/vtec?
  9. brian11to1
    No. Why would you need a "gsr" oil pump if your running a "gsr" water pump?
  10. ls/vtechatch91
    ls/vtechatch91 New Member
    washington
    gsr oil pumps give you alot more oil flow than a ls.... wich is a must when ur doing ls/vtec..... thats what im doin and i went to honda and bought a new one......it was like $130 with my friends discount.....
  11. tartymctang2357
    philadelphia
    ^^ :thumbsup:
    plus the teeth of the gsr timing belt wont match up with the ls oil pump if i remember correctly
  12. brian11to1
    lsvtechatch91 - proof? As a matter of fact, judging by part numbers from 96+ b series oil pumps all had the same part numbers... that being 15100-P72-A01 where as 90-95 oil pumps had the following part number 15100-PR4-A03. The part number 15100-P72-A01 doesn't just apply for GSR's... it goes for the LS, ITR and GSR.
    I bought my "itr" oil pump brand new for $90.
    96-01 LS oil Pump
    15100-P72-A01
    Acura Parts @ AcuraAutomotiveParts.org - Genuine Acura OEM Parts from Acura Carland
    96-01 GSR oil pump
    15100-P72-A01
    96-01 ITR oil pump
    15100-P72-A01
    90-95 ls oil pump
    15100-PR4-A03
    92-95 gsr oil pump
    15100-PR3-024
    The timing belt has NOTHING to do with the oil pump. The timing belt does not drive the oil pump, the crank shaft does. The timing belt rides on a gear located on the snout of the crankshaft.
  13. ls/vtechatch91
    washington
  14. tartymctang2357
    philadelphia
    i think he means proof of the better flow
    wow i royally fucked that, i'm completely wrong on the oil pump and timing belt thing, its always match the timing belt to the water pump not oil pump, wow... just wow... i apologize brian was right
  15. brian11to1
    haa... thats funny. i was just making sure you werent confusing yourself...
    and yea, proof that the "vtec" oil pump flows better... than a "nonvtec" oil pump.
