head removel
what is the best way to remove the head bolts. i tried with a socket but couldnt get it to move should i use a breaker bar need help asap :worthy:
increasingly the length of the lever arm increases the torque- Using a breaker bar will def. allow you to apply more torque-
otherwise you could always slip a section of stiff pipe over the breaker bar, then you'd really making a lot of torque- just be careful not to break anything
