cxjon Senior Member Sep 9, 2003 #1 my car is obd 1 and if i use a d16a6 head can still be obd1 or do i need to do a little wiring to make it work
J josh Junior Member Sep 9, 2003 #2 Yes it can, you just have to use the obd-1 distributor (Which will have to be slightly modded)
J josh Junior Member Sep 11, 2003 #4 you will just have to grind out a couple of the distributor bolt holes
