header for sir2 swap...
ek2ner_knox
i have a 96 ex awaiting a b16 sir2 swap from the 92-95 model civic...it comes with the stock manifold...will that manifold work or do i have to buy an aftermarket header and if so which header do i have to get...
Any b series header will fit the motor. As for it matching up with the rest of the exhaust on the car I would guess theres a chance it would.
it works perfect I have the same car with the same swap. If you had a cold air intake on your d series make sure you buy a new one or go back to the stock box... there is about 4mm diff and it will throw it off just enough to start rubbing.
