header length ?
Discussion in 'HYBRID -> EG-EK / DC' started by deity, Jun 12, 2005.
  1. deity
    deity Junior Member
    does anyone know much difference in length is there between the gsr header stock. and the b18b header stock?
    i ask this because im going to have an exhaust stop extend my header to mate up to my catback and i need a length.
  2. sihatchback_RL
    sihatchback_RL Senior Member
    B18B won't fit, B16 is what you need.
  3. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Not if he's got a 1.8....a B16 header is too short (valve cover to oilpan) because a B16 block is around 8mm shorter than a 1.8 block.
    I dunno the exact length...it's a couplea inches. Just drive up there with open header and let the muffler shop put in a piece of pipe whatever length it needs to be.
  4. sihatchback_RL
    WRONG, a B16 does fit, Numerous of my friends with GSR swap in EG has B16 Unit, Even i have the setup when i first swapped it in.
  5. thr33niL
    thr33niL Member
    SERIOUS??!?! You mean all I have to get for my 95 Civ Coupe and GSR motor is a B16 header and it would mate to my civic cat and exhaust?
    :::crossing fingers::::
  6. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    I am almost positive that it will, and currently am looking for one locally so I can finish my swap.
  7. thr33niL
    thr33niL Member
    Keep us up to date on it. I have been messing with my exhaust for 3 weeks trying to avoid a muffler shop. I am :::this::: close to just getting a GSR header and taking her to get fitted.
  8. asmallsol
    For my del sol, My exhaust wasn't the best (muffler shop custom job, crush bent pipes, fat can thermal muffler and my GSR manifold was a few inches short. So instead of going to the muffler shop, I cut the muffler a few inches after the cat flange, and then stuck a slip joint pipe to make up the diffrence.
    Here is the outcome..
  9. sihatchback_RL
    Trust me i put my two cents on the flop that the B16 header will fit. I have swap over numerous GSR in EGs and just took off a header from a blown B16 and slap it on. ANOTHER thing is that you can't use a GSR cat. the stock civic will bolt, with little manly force.
  10. thr33niL
    thr33niL Member
    sihatch, you 100% freakin right.
    I took your advice bro and bought a 99-00SI/94-97DelSol DC header and it fit perfect!
    Thanks a million man. So much cleaner than chopped, muffler shop type fixes.
    So this is double confirmation.. Anyone swaping a B18C into an EG civic can use a DelSol/SI header to span the notorious gap between the collector and cat.
    NICE
  11. younglord94
    younglord94 Member
    is it the same in an ek civic i'm putting a b18b1 in my hatch
  12. asmallsol
    thr33l, on the b16 header, is there a O2 bung on the header portion. Because if you use your civic cat, there is no O2 bung on it.
  13. thr33niL
    thr33niL Member
    Yeah on the B16 header I got (DC) there is an o2 bung down by the collector.
  14. thr33niL
    thr33niL Member
    I really cant say for positive but since the header I bought is fitted for 00-01 SI's, if I had a guess, I would say yes.
  15. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    B16A header will fit, it's just real tight. It should have an o2 bung by the collector no matter what the year it is for, as they all (US models) have one there, just the obd II ones have one on the cat too.
  16. 92civicb18b1
    92civicb18b1 The Trisexual
    my obd1 92 b18a1 header only had one in the middle of where the heat shield would be. maybe 7-8" from the head. There wasn't one furthur down. That was a pain in the ass.
  17. formby
    formby learning in progress
    it will fit i used an oem b16 header on my lsv....for almost 6 months
