Header Paint?
Discussion in 'General Tech and Maintenance' started by GlassHeadlights, Mar 5, 2009.
  1. GlassHeadlights
    Calgary, AB
    Does anyone make a paint to put on an exhaust manifold? Or would I have to powdercoat it? I was only going going to paint it black.
  2. Ethan
    Ethan Well-Known Member
    I had some but i cant remember who made it. Ill look for it and send a link.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    all the ones ive ever used didnt last 15 min after start up.
  4. Ethan
  5. Ethan
  6. GlassHeadlights
    Calgary, AB
    Maybe I'll just let it rust. :dunno:
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    clean the header really well,and use the really high heat shit,it should be ok
  8. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    Header wrap seems to help out with anti-rusting.
    Here is a pic of what mine looks like, damn this is an old pic, before my valve cover and stuff.
  9. newb
    newb phresh VIP
    Backwoods Northwest
    My experience with header paint is, if you always drive the car its not worth it. If you always drive the car, its just gunna burn off, but so will the moisture so the header wont rust too fast. If the car sits a lot, theres no heat to evaporate the moisture so paint would help. Just my .02
  10. GlassHeadlights
    Calgary, AB
  11. GlassHeadlights
    Calgary, AB
    What about powder coating?
  12. Ethan
    They have DIY powder coating kits now. you bake the shit in your oven.
  13. Ethan
  14. MthaFuknGreen
    Lodi, CA
    get a real header or just have yours chromed.
  15. GlassHeadlights
    Calgary, AB
    Ya really. It's a stock exhaust manifold. I'll cut off the heat shield extensions then just let it rust. I may wrap it though. Idk.
  16. eg6sir
    high temp flat black... sandblast it first and it should stick
  17. newb
    newb phresh VIP
    Backwoods Northwest
    No dice. It will look like shit after a while, I promise. Any exhuast parts will if theyre powder coated.
  18. MthaFuknGreen
    Lodi, CA
    see if whistlercowboy can help you out..
    i think thats his name.
    from what ive seen of his work, hes a powdercoating master.
  19. Wilshire
    Wilshire Big WIll
    nor cal
    ive heard that header wrap can eventually crack your header because theres no where for the heat to escape to, its all held inside... is there any truth to this??
  20. Justin66
