header ?
jadams92
hey guys got a couple of ?s for you i have a 93 eg coupe with a ls in it the block is a b18a1 and the head is a b18b so wat header do i need one for the b18a or b18b or are they the same also i want to go to stock exhaust but dont no witch cat to buy one for the b18 or one for the civic any help would be greatly appreciated thanks
Yeah any B18a/b/c header will work but may need to modify the exhaust slightly. Get a 4-2-1 if a daily street car as they make more power in the lower and mid range a 4-1 will not get you much unless you have bigger cams but better than both is a Hytech style. Makes great power across the full rpm range.
