B bak1 Junior Member Aug 31, 2004 #1 my 2nd to last header pipe off the header is leaking gas what is the problem..the injector i changed and plug and still is leaking whats going on help
B brian11to1 Senior Member Aug 31, 2004 #2 If the header is leaking why did you change injectors? Maybe you should try re-torquing the header bolts?
