Hello from Serbia!!!
rmush
Hello Honda community, I'm Rasha and I living in Serbia, in litle town, his name is Prokuplje.
I will(wish) good health to all members in our community.
POZDRAV!!!
MY AND MY BROTHER "CHIPC" HONDA
Celerity said:
I dunno.... Since the Ottoman empire, do Serbs and Albanians get along still ?
VERY HARDLY!
SERBIAN STATE=before 500 years
ALBANIAN state= before90 years, but that don't matters
Albanian people living in KOSOVO and ALBANIA(USA, and over state's on World)
Serbian people living in Serbia, Kosovo , Croatia, Bosnia()......(USA, and over state's on World), but that don't motive our community!
You don't understand that, this is long , long story......
BodyDroppedNikes said:
welcome to HondaSwap. what is done to your Civic?
Problem in my Civic is code error 6 water temperature sensor, and I folow manual:
but cant buying in Serbia because sensor don't sale in my country!!!
reckedracing said:
car should still start with a bad ECT sensor
it should even start if you unplug it
Yes start every time, but don,t start 2-3 time when is themperature outside "traverse"
38 º C. Problem has being in main ralay. Sorry for badly english.
code 6 is the ECT, correct
but manual what?
thermostat for the motor...
the ECT is the 2 wire coolant sensor off the head
tells the ECU how hot or cold the motor is to adjust fuel and spark
unplug it and try to start the car
i have never seen an ECT sensor make a car not run, it may run all fucked up, erratic idle, etc, but it should still start
and how do they not sell the sensor in your country?
sounds like you have this all figured out already?
lol
high outside temp, no start condition = main relay... correct
but manual what?
You will back fire, smell fuel,get horrible gas mileage,idle will be sky high. ALl because you are running rich as hades! Change the little bastard before it get worse. Its under the VTS and cost about $25. I had the same problem.
what happens is.My problem is next: That sensor tells the comp how hot your or cold the car is running. When its cold its sends alittle more fuel to get it going for a while. It lvels off when the car hits operating temp.When it goes bad the majority of the time it tells the ecu its cold when the car has reached operating temp and therefore" dumps mad fuel".
Machine start every time, but himself bandy gas, accelerate himselfe ( 3000 rpm)!
reckedracing said:
it idles at 3000 rpm?
Yes magic word idles! Thanks, yes correctly, sometimes 3000-3500 rpm ,
(before 500-750 rpm)
