****HELP: 89 Si idling weird :[****
Amoney47
okay so i have a 89 ef with 182k miles and it is bone stock (bought it yesterday) start up and idling for the car warming up is fine...once the car is warm and i drive for a little bit the idle goes from 1100 rpm to about 600 constantly just rah rah rah but when reved back up to 1100 rpm it is fine.. any help would be appreciated
going through this post may help
https://hondaswap.com/civic-crx-ef/hunting-idle-issues-253238/
a lot of people run into this this thread will likely follow a similar path, if it still doesnt work post what you ave done and go from there.
usually a clogged IACV will cause this. its a small black cylinder thing located on the back of your intake manifold with a 2 pin plug going into it, accompanied by some small hoses.
