HELP!!!!!90 DX Swapped b18a1
Discussion in 'HYBRID -> ED-EF / DA' started by youngking434, Aug 31, 2010.
  1. youngking434
    youngking434 New Member
    Jut Got A CRX With A B18a1 Swap And When I Go To Start The Car The Only Light That Comes On In The Dash Is The Battery Indicator Light.
    I Have Replace The Battery With Yellow Top..Still Doin The Same Thing,Dont Kno Wat To Do....:confused:
    Any Ideas???
  2. money b
    money b New Member
    does it just do it when starting cuz my b18b jdm civic dx does it... can you help me? i need to get the wire color and location of the wires on the engine harness clip driver side... also did you delete the risistor box?
  3. youngking434
    yea... but it wouldnt start....and idk and i still have the risistor box hooked up.
  4. money b
    money b New Member
    does it try to turn over? you could have the starter wire not on.. the battery not tight.. or the ground off your battery hooked up.. also their is a wire that goes to the fuse box.. make sure they are hooked up and makin a good connection.. could you look at the plug and listt out the location and the wire colors on both sides please.
