help ABS light on
aLlmoToRcOupe
i want to know how can you turn off the ABS light. This how it turn on, i was changing my shocks spring and turns and that my ABS came on after i put everything back together. i just had both axles replace and it still comes on. what can i do to turn the ABS light off. thans
I have the same problem in Civic hybrid 2006 , not only ABS light also Break System light on after repair the front right axle, and auto-stop feature doesn't work also after that...
What is the model of your car ?
Make sure your new cv shafts(axles) have the same reluctor rings for the wheel speed sensors. Also check all wheel speed sensors and wiring for damage/corrosion.
