Help! Asap!
Discussion in 'HYBRID -> EG-EK / DC' started by turbo4door, Nov 4, 2009.
  1. turbo4door
    turbo4door New Member
    i having weird problems with my car lately. 1994 civic lx 4 dr with d16y8 swap.
    the issue is when the car is running it will randomly start missing on cylinder #1 then it will run fine again. sometimes it will happen as soon as i start the car and sometimes i will drive it 50 miles and not have the problem.
    i have replaced many things and still can't find the problem.
    replaced:
    fuel pump, plugs, distributor, wires, engine wiring harness, ecu.
    can anyone help this is my only car!
  2. Briansol
    injectors?
  3. tabKola
    tabKola New Member
    Tewksbury MA
    Might be wiring to the injectors or to the distributor.
  4. pooksy64
    pooksy64 RidetilldeathdousparT
    HOUSTON tX
    what about distributor???? the dis has the cmp sensor and TDC sensor built in it
