Citizen_Insane
I just finished wiring everything for my b16 swap and it won't crank over. Yes all the grounds are connected and I'm almost positive everything is connected right. The only thing I'm shaky on is the wiring for my starter motor.
-What triggers the starter motor? I assume its the gound, because the + side of it is connected directly to the battery. I'm thinking I connected the wrong ground to it so its not getting any power.
-Which ground do I connect the starter to? What else is near it on the wiring harness.
Thanks for the help
-Kai
Thanks for the help
-Kai
