Just to say I havent had this car running in 3yrs it was garage stored though. I am pulling codes 3,5,7. All indacate Map and tps sensor. Well i whipped out the volt meter for the tps. When close 2.5 when open .12. So i swapped the sensor out with another one. Now when close 4.5 and open .45. So i though the wires might be crossed so i switched the yellow and red. no start weird voltage. Switched back same thing. Could my other sensor be bad or is my ecu shot. I mean i map sensor being bad shouldnt throw off the voltage of the tps. Also i have a
Honda 68mm Throttle Body (P/N 112-511 & 112-540). Iam looking for some help here. Thanks!!
