HELP - B18A1/B1 question - and broken engine mount
Ok, 88 Civic HB, doing a B18A1 Swap.
Went to start prepping the motor and folund that someone broke one of the bolt holes on the motor, the one between the timing belt... so the motor is fubar'd...
Would of been a good motor too...
I found a B18B1... what would i need to do to put the B18B1 in the B18A1's place...
Keep in mind I have ALL the parts for the B18A1, ecu, axles etc...
