Hi,
I am swapping a B18B out of an 01 integra into a '94 Del Sol. Got almost everything bolted-in, except for the shift linkage. The linkage that came out of the 01 integra is about an inch shorter than what I need. Can someone confirm this? I have been told that the B18B shift linkage should work in my car, but it's not. Any suggestion on a fix? I was thinking about having someone (a welder) extend it. Good idea? Is there a shift linkage that would work in my car? How much would it cost?
Another problem that I have is the vacuum hoses coming out of the Charcoal Canister. On the D16Z, There are two hoses that come out of the canister and plug into the intake manifold. On the B18, I find that there is only one vac. hose input (located on top of the intake manifold), and it's a larger opening than any of the two hoses I have. The opeing is for some sort of sensor. I don't know what it is. I know for sure that it's not the MAP sensor. When I start the car, it seems like it's sputtering. When I put my finger to plug the the larger opening it helps a little (lowers the RPM too). What should I do?
Thanks in advance!
Thanks in advance!
