HELP!!! bad mpg
Discussion in 'Civic and CRX - EF' started by akronboy89, Jan 12, 2009.
  1. akronboy89
    akronboy89 New Member
    ok i got a 89 civic hatch it has the stock motor and a 4 speed trans. it has a header and a full catback and im only getting like 200 to a tank. on my ecu im getting 1 flash then 17 after the pause and dont no what that is. i do get a check engine light when i drive slow for some reason some one help
  2. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    Check your Hayne's manual and see what the code means.
  3. efhondakid
    Akron-Canton, Ohio
    Code 1 is O2 sensor and 17 isnt a valid code, its for VSS, your VSS is cable operated, so it may be 10 and 7 which is IAT sensor and TPS sensor. All these controll fuel it my be one or combonation of all three. Start out with a new O2 and see what that does for you. Then the IAT sensor as the TPS sensors very rarely go out.
    1 person likes this.
  4. Luis998
    Orlando, Florida
    Byron, all I have to say is REP! :thumbsup:
  5. akronboy89
    im going to buy a new o2 tomorrow but dont no what one is better they got a bosch and a ngk i think the ngk would be. and efhondakid what kind of car do u have?
  6. efhondakid
    Akron-Canton, Ohio
    No need for rep. I just know how to use our reference section, if I had a nickel for everytime Ive used the ECU code list, well Id have quite a few nickels.:D
  7. efhondakid
    Akron-Canton, Ohio
    Not really going to make a difference whch one you go with, they both will do the same thing. 89' DX with a JDM B16.
  8. Luis998
    Orlando, Florida
    I've had such a shit day that I didn't even think of checking there. :(
  9. akronboy89
    i was just down in canton over the weekend looking at a ef hatch with a b16 and a stock one just though it might of been u haha. and im on my phone its hard to do some stuff on this site
  10. D16SiHatch
    D16SiHatch New Member
    How is code 17 for vss not a valid code. if you unplug the cable from the trans you will get this code. the speedometer will no longer function and the ecu won't receive a vss pulse from the gauge cluster.
  11. akronboy89
    well my speedometer works i want to do a swap here when i get my incom tax
  12. eg6sir
    its most likely your O2 sensor causing you to run rich.. thus giving you poor MPGs
  13. |Chaz|
    |Chaz| Well-Known Member VIP
    I've been getting really shitty mpg lately too... sucks :/
  14. MthaFuknGreen
    Lodi, CA
    get a dodge circuit.
    lol
  15. !JDM_EF-9!
    !JDM_EF-9! I'm just EF'n..
    cailfornia
    so wat do you do??
    Just get a new o2??
    Cuz his problem sounds the same as mine only that i got a b16 swap in mine car..
  16. eg6sir
  17. jimmyvong
    jimmyvong New Member
    Fort Worth, TX
    Exactly what EF kid said. Good luck.
  18. Magana559
    Magana559 The Warden
    fresno Ca
  19. efhondakid
    Akron-Canton, Ohio
    Wouldnt happen to be Dustins would it, red with body kit, black front bumper?
  20. akronboy89
