well actually, the car stopped running around sept. last year and I just have got around to trying to fix it. The car is a 90 CRX bone stock and it just died while driving.
What I have done to it so far:
checked timing belt-OK
checked for fuel at fuel filter presure releif-fuel came out but not shooting, asuming fuel pressure ok? - tried starting fluid just to see if it would fire and it diddnt.
checked for spark and found that the cap where it goes into the coil was completley
burnt off and could not find any pieces of it when I took off the cap. so then I replaced the cap with the one off my B16 (just had to cut out a little notch out of the cap) and checked for spark and I had it.
just two weeks before this car stopped running I did a general tuneup- cap, rotor, plugs, wires, fuel filter, air filter, oil, and topped off the transmission.
What do you think is the problem? maybe the timing belt jumped a few teeth? I am at a loss.
thanks, Liquin
thanks, Liquin
