turboteg117
PartsGuy
Hey guys whats up? I need some held deciding on what cams and clutch to get for my 97 teg, I will just give you a lil' heads up of what I got ( LS/Vtec Turbo, head has supertech valves and skunk2 valvesprings and retainters, it has a stage3 port and polish and 3 angle valve job, it was takin to the machine shop first to get the ordinary procedure done.. milled, cleaned, resurfaced. My block has been also cleaned, milled, resurfaced, honed and bored to 2.0 it has Eagle rods(Eagle crank) Cp pistons 9.2-1comp, apr rods and bearings. My intake manifold was cut open and bored out ALOT and I have a JG throttle body 68mm, Aem fuel rail, Aem fuel regulator, precision 660cc injectors, walbro 255bhl fuel pump. Turbo kit was pieced together I have a ERL manifold, custom Garrett turbo, Tial 38 wastegate, Precision 350rated intercooler. tuned with hondata s200.
Thats basically it.. I know I have to be forgetting somethings so just let me know if you have any questions. But I was want some opions, Thanks for your Help it will be much appriecated.
-Shane
-Shane
