I put my clutch together again today, still brand new clutch, pressure plate, and throwout bearing. I had the flywheel ground down just to be safe. The motor is out of the car... I put everything together and pull the clutch lever...not much resistance until it is almost all the way up, only has half inch or more to go. I have someone hold the axels and I turn the crank with a wrench and the axels still move and we are not able to get the clutch to slip. The tranny, flywheel, clutch, pressureplate and piolet bearing are all for an 88 si. What am I doing wrong? I have posted this before but no answer and I can't find anyone who can help.
