Help!!!!!!! D15b
mouse323
I have a 93 EGwith a D15B, the problem is that it idles up and down when its warmed up. If the motor is cold it"ll sit just fine. What can the problem be?:confused::confused::confused:
Have you tried cleaning the IACV and FITV(if equipped)? Also, try unplugging the IACV when it's warmed up.
No, it's not throwing any codes. I checked for vacuum leak and nothing. I gonna check the IAVC.
So I unplugged the IACV and it worked. Thanks.
Now my other question. Would any IACV off these engines
,D15B8, D15B7, D15B7, D15Z1, fit a D15B?
B7 should be the same, not sure about the others. I can actually check since I all of those engines! lol.
Yes; D15B VTEC has the exact same manifold minus the purge solenoid.
All of the D15s asked of all have the same IACV. Only difference I notice was the rear plastic color was either black or white; but uses same connector.
