Help! Ebay'd Again!
Discussion in 'Engine Building' started by EKJOE, Mar 31, 2009.
  1. EKJOE
    EKJOE New Member
    Hey guys....I dont know why I keep doing this to myself, But im done now...Promise.
    I ordered a set of 81.25mm p30 pistons and rings from Ebay member "FOREVERJDM" heres what they sent me.
    Piston Part # P30-000
    Rings Part # PR3-003 (USDM?)
    The pistons are 81mm standard bore and the rings im confused on, .3 over size? They are for a 81mm piston but would have to be file fitted?.
    Either way, these guys ****ed me. Their communication is virtually non-existant. I just filed a dispute with paypal over the whole thing.
    Here's my question. Who knows the Honda part #'s of the 81.25mm p30 pistons and rings?
    I just want to make sure I buy the right parts this time.
  2. Briansol
    These are the honda part numbers for b16 pistons:
    13010-P30-G00 Standard Bore Piston
    13020-P30-G00 .25mm Oversized Piston
    13021-PR3-003 .25mm Oversized Piston
    13011-PR3-004 Standard Bore Ringset
    13021-PR3-004 .25mm Oversized Ringset
  3. EKJOE
    EKJOE New Member
    Ok here's the full part numbers of what I have in my hand right now.
    The piston number doesnt exactly match yours, Whats the difference here?
    Piston: 13010-P30-000 I know for a fact this piston is standard bore.
    Rings: 13011-PR3-003
  4. Briansol
    typo on my behalf. 13010 is correct.
    looks like you got std's
    the 003 to 004 is most likely the "generation" replacment. 3's are probably older than the 4's
  5. Briansol
  6. EKJOE
    EKJOE New Member
    Thank you very much B, I should have came here first.
  7. EKJOE
    EKJOE New Member
    It says right on his post he cant get JDM parts :/ Hmotorsonline has em but it looks like they only have standard bore.
  8. Briansol
    p30 parts aren't just JDM... they are available from the usdm del sol b16a3
  9. Newfie_Sol
    Newfie_Sol New Member
    Newfoundland, Canada
    I just took apart my 94 del sol with a b16a3 and everything inside is PR3.. stamped on rods and pistons..
  10. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Yeah, for some reason Honda loved stamping B16's with PR3, regardless of what year they were.
