HELP!!! eg with gsr swap
mrg35
i have a 92 eg swapped with an b18c1 obd2 block. head went out on me so I rebuild a 95 head i had laying around. NOW my question is:
Would I need to convert my distributor and Fuel injectors or anything else i might be missing to an OBD1 or can I just keep it as OBD2 for those parts???
any VTEC B series distributor will fit... your only concern would be the plug being different... because you are already wired for OBD-2 you might as well stick with that
