Help, engine is throwing cel 54
Discussion in 'General Tech and Maintenance' started by Buktheng, Dec 27, 2004.
  1. Buktheng
    Buktheng Member
    PA
    Ok, I just changed the ecu in my car back to a p72. I originally had a p28 ecu w/ an obd2 to obd1 conversion harness. So when I put the p72 back in, it gave me an engine checklight code 54 CKF - crank fluctuation sensor. I know that the p28 doesn't mean the sensor hooked up so where exactly is this sensor so I can hook it back up? Can anybody take pics to show me?
  2. Buktheng
    Buktheng Member
    PA
    Ok, where does the crank fluctuation sensor plug into? I think I found the plug and its unplugged but i can't find any spot to plug it in.
