HELP f22 to jdm h22 - cylinders flooding with gas!
nxtgenben
So, I have a 96 prelude (OBDII) and I swapped an OBDI jdm h22a engine into it.. Car finally runs, after practically having to make a harness from scratch. But when I give it throttle, the engine sputters and dies, sucking for air. It has the proper fuel pressure at the injectors, everything tests out ok so far.. but the cylinders are flooding with gasoline, its running wayy to rich.
Any ideas???
help is MUCH appreciated.
