My fans stopped working in my 1999 d16 I checked the fuses and I even traced the visible wires from both fans to see if the insulation had worn anywhere and it hasn't. Need help fast
Jump the fan switch directly. If it doesnt come on at that point, than look into replacing the fan switch or clutch/assembly. Doing this puts direct voltage to the load, which will turn it on if it is not broken/seized.
