help finding a sensor
slamedciv
ok i have a stock 96 ex and the check engine light came on so i had it ran and it threw up the crank fluctuation positiong sensor and where the hell is that plz help and if u know where it is how do i do i instructions plz??
i'm pretty sure it is on the bottom of your engine, by the crank pulley. If you are looking at your engine.... on your right side there will be a wire coming out of the plastic cover near the bottom of the engine.
