Sorry, I can't find the edit button.
I messed up the instructions. Here's a cut and paste:
1. Turn off ignition
2. Connect the SCS service connector (or paper clip) to the 2pin wire you take out of the drivers fuse box and is now hanging from a thicker harness.
3. Turn on ignition
4. SRS light comes on for 6 sec and then goes off. Before it has been off 4 sec, Remove the SCS connector (paper clip).
5.SRS light turns on again. Reconnect the SCS service connector withen 4 sec of light coming on
6. Light goes off, remove connector witeh 4 sec after light went off.
7. SRS light blibks 2 times telling you the memory is erased.
8. Turn ignition off for 10 seconds and start car
