HELP finished manual swap running like sh*t 92 accord
Discussion in 'General Tech and Maintenance' started by BigSpec007, Mar 3, 2008.
  1. BigSpec007
    BigSpec007 New Member
    Hello all, I'm a noob on this site and need some help, I just finished an auto to manual swapon a 92 accord as well as engine swap, all stock just rebuild nothing fancy is for a friend of mine.any way I finished the swap mostly the reverse lights still havent been worked out but this problem is about the engine. Runs like crap wont rev over 3000rpm lacking power,idles just under 1000rpm, it idles fine but when your driving the car cannot get out of its own way. I did change the ECM from the auto to the manual,and we did have a problem with engine harness, but it just lacks power.
    Any suggestions?anyyone?
  2. jeffsciv23
    jeffsciv23 Senior Member
    Wa
    your in limp mode, check you CEL's and see what they say
  3. BigSpec007
    where would I find reference on checking the codes for a 92 accord i searched with no luck but i will keep looking
  4. jeffsciv23
    Wa
    try the referance section
  5. BrutalB83
    Rochester Hills, MI
  6. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Bridge the little blue plug under the right side of the dash with a small piece of wire, turn the key on and count the number of times the check engine light blinks. Should be in the manual....I assume if you did a trans swap you have a manual.
