thehomedoctor
A month or so ago my crx was idling at a lite and started revving up on it's own then it was fine again. Same thing a couple weeks later. Then for a couple weeks it began not starting after initially catching... like the spark was getting turned off after it started.
I've figured out that the fuel pump is still getting gas past the filter... at a pretty good rate but I don't hear the fuel pump with the key on.
This is a $500 crx that's turned into a $1800 car after a new head, tires etc and now I'm going into busy season and don't have time to work on this so i want to narrow down the repair options for the Symptoms. Any help would be greatly appreciated
