Help h23!!!!!!!
Discussion in 'Prelude' started by DESPAIN, Sep 14, 2009.
  1. DESPAIN
    flower mound TX
    Ok i have a 92 prelude i am working on. I can get it to start if i barely push in on the gas. But it only starts for a sec. Then dies. Will not idle. Sounds like air coming out of the throttle body? Have not done a comp. Check yet. I wonder if its the head or what? Thanks in advance.
  2. DESPAIN
    flower mound TX
    bump! plase help asap!!! thanks
  3. reikoshea
    Dallas, TX
    do you have a CAI on your 'lude? With the weather we've been having (arlington was hit the worst by it) you might have sucked water.
    I doubt the main relay would be acting up on you since its been 70 degrees all week, but when my H22 lude was doing that i replaced the main relay and the fuel pump and all was groovy.
  4. 95b16coupe
    95b16coupe New Member
    ct
    check your timing. check all of your grounds. check your fuel pressure.
  5. DESPAIN
    flower mound TX
    timing is off a little grounds are good. the kid was doing 120mph and it just dies. i am sure he fu**'d up his head i am just wondering if his bottom end is ok? how can i tell if its huis head and not his pistons?
  6. 95b16coupe
    ct
    ummm......take it apart?
  7. DESPAIN
    flower mound TX
    yeah just hoping there was an easier way i didnt know about.....
  8. 95b16coupe
    ct
    compression test and a leakdown test. thats about it.
  9. necessaryevil
    necessaryevil New Member
    in da 503
    i just drop in a replacement h23 for a friend and was having the same problem, checked valve lash and readjusted and it ran fine, we have no idea how they got out of wack since it came out of a running rig but i guess it did.
  10. DESPAIN
    flower mound TX
    i have an extra h23 sitting in my garage. using the head off of it. just going to swap heads. its not in the best shape but at least i know that it runs.
