What do you guys recommend for increasing my traction ability when i launch? Its completly stock suspension with 195/50/15 Cooper cobra's . Once the tires go im going to upgrade to 205 Falkens. But i was looking for advice about the suspension
thanks
get the ground control drag setup
get some adjustable struts
you want to lift the rear (to put more weight on the front tires)
and you want to have the rears stiff as fuck (to reduce weight transfering off the front to the rear)
falkens are NOT drag tires. you'll bake them up. they are autocross tires, and are great for 2nd - 4th gear hard driving, but will net you a 2.5 60' most likely still.
The Falkens are not good drag tires. I had the Ziex and the Azenis, and didn't like eather for take off's. They have a stiff sidewall, better for auto cross.
or you can go to home depot and buy a tube of urethane caulk ( its called.. " window something".. it escapes me right now).. it's black.... and fill in the stock mounts.. same thing... but cheaper
